Hose connecting Air balance pipe
Does anyone have a part no or US source for the rubber hose that connects the air balance pipe and the intake manifold? I'm having a hard time finding it on sng barrat.
Its got a slight elbow to it.
By "air balance tube", i mean the metal pipe behind the V12, near the firewall that connects the left and right manifolds.
I've replacing all the vacuum lines on the V12, and I'm seeing that there's a variety of sizes.. i just took some hoses to AutoZone, and was pleasantly surprised to find that they did not charge me for it. However, if there was a kit or a list of sizes that I could order online, that would be a lot more convenient..
I know theres the hose from the center of the air balance pipe to the ecu in the trunk, but i also see some others that run behind the firewall. What are those? Dont recall seeing them in the vacuum diagram
Thanks Grant.
Also, the plastic part #18 on this diagram has disintegrated, both classic jag and sng don't list it. Any sources? It's the plastic sleeve in which the throttle rod rotates
http://www.jaguarclassicparts.com/il...ges/ld8110.png
Received 10,914 Likes
Thanks Grant.
That's C19706....but I don't think that's what you want.
The nylon/plastic bushing that's typically replaced is C34388, #12 in this illustration
Part no. C34388 | Bush parts from Jaguar Heritage Parts UK
Google the number, lots of choices. Some replacements are made of such a rigid material that I'm unable to install 'em without trimming them down a bit
The following 2 users liked this post by Doug:
Jonathan-W (12-28-2015),
TheWarlock (12-31-2015)
for the cross over pipe I bought this from Ebay, just check the size. no problem with it attaching 1" Venair 1 Ply Silicone Heater Hose for Radiator Coolant Blue Sold by Foot | eBay
Vacuum lines, again from Ebay VMS Super Detail Vacuum Hose Kit Line Black 3 5mm 4mm 6mm 8mm 10mm | eBay
On the vacuum line, i need a really long hose to go from the balance pipe to the ECU, what size and length is that line?
There is a metal pipe about 15" (memory) down from that crossover pipe, and that pipe runs to the rear, where a smaller hose takes the vac to the ECU spigot.
Lee Saxon
12-28-2015 05:51 PM
