Hot air when heater is turned off
Received 10,979 Likes
So if the aircon is not working, that might well be a factor in confusing the system, which will be looking for a given low temperature in the cold chamber.
If the RHS knob is at off, then I think the flaps on the inlets to the system (which are part of the fan assembly each side of the dash) should automatically close. Though this feature may be activated only when the car is actually switched off, I cannot remember. See, when you actually switch off the car, if you can hear some flaps closing. I can on mine, but even after all these years I do not know if that happens when I switch off the aircon system with the knob!
I do not lightly disagree with Doug, but I have a feeling that even if the system is switched off (unless you are calling for full cold - the lowest temp setting on the LHS knob) the water valve remains open, and this should not in itself affect airflow into the cabin, which you are obviously getting somehow when the system is switched off.
Greg
Greg
Greg
In asking for more info I myself reply I was a bit too economic with words.
In some convertibles the system is never actually off, even with the control knob turned to 'off'. The system, at least some portions, remains powered up so the compressor will run and provide fuel cooling.
But we now know that isn't relevant, so onward we go !
Ok, good, from that we know A) it isn't a later convertible and B) you have the Delanire MkII climate control.
The system is a little tricky but my thought process begins with fundamentals.
Air coming thru the screen vents certainly suggest the defroster flaps are open. And the defrost mode defaults to full heat. (and, if in thinking about it, the heater valve is always open in all modes *unless* max cooling is called for). And, by design, the defrost mode bypasses the 'auto' aspect of the system.
Next question/test:
With the mode knob set to 'auto' slowly turn the temp knob thru it's range, allowing time for the system to respond. You should hear a slight whirring sound and hear the internal flaps operating. If you do then we know the system is at least fundamentally operational and is at least trying to comply with requests. No sound at all tells us the system is fundamentally non-operational....and that issue must be addressed before going any further.
My thinking is that if the system failed in while in defrost mode then there's nothing to bring it *out* of defrost mode.
Next question/test:
Greg is correct the heater tap in the engine bay is on all the time unless the AC is on full cold. This causes hot water to flow through the heater matrix heating up the AC box with the AC off and hot air comes out the vents.
The foam surround on the air flaps may have disintegrated causing air to leak. Mine is like this and a nightmare to fix.
What Doug said is also a common problem and one cause is coolant leaking from the heater matrix onto the connectors.
No vacuum = valve open
Vacuum applied = valve closed
In 'normal' operation the system keeps the valve open (no vacuum applied) at all times *unless* maximum cooling is dialed up on the temp control. When max cooling is requested, vacuum is applied to close the valve
JigJag (03-05-2017)
Other way 'round...
Just run a vac hose from the heater valve to a vacuum source....tee-in-to an existing vacuum hose or whatever....so that vacuum is applied all the time.
