How did you know you needed you rebuild your front end?
I rebuilt the rear end last summer, well, not really, someone had, but it needed new radius arms so I did those. The front end has a little slop. The XJS is my trusted backup car when the Italian has problems, which is often. I have have 129k miles to be hones but the car is mint otherwise. I'm thinking:
Ball joints upper and lower
Control arm bushings
Sway bar end link bushings and connecting bushings
Am I missing anything? I have a huge garage and will probably do this myself unless I get told that I have to travel or something.
The following 2 users liked this post by jal1234:
Greg in France (03-26-2022),
orangeblossom (03-26-2022)
Check the wheel stub axles too; if there is wear track on the bottom side where the bearing inner race loads are, replace them too. If you do all this, or check it all for being 100%, You will end up with a car front end driving like a new one. I have done this over the last 2 years and it is a joy to drive it.
TIP: for the absolute best ride/handling I use Boge shock absorbers on the front. These are OEM in fact, and I have just changed the upper shock absorber rubbers to rubber UNDER the wing (with the special OEM metal cup washer in place) and POLY above the wing with NO metal washer. You will not believe the difference this made to the ride! Fantastic.
The following 5 users liked this post by Greg in France:
Dukejag (04-11-2022),
Grant Francis (03-26-2022),
LnrB (03-26-2022),
Mkii250 (03-26-2022),
Greg in France (04-05-2022)
Received 9,213 Likes
You'll need to support the engine when you remove the subframe. I use this support from Harbor Freight which works great. I've used it more than I thought I would. https://hftools.com/app96524
I have a hoist and a crossbar for shock towers, I'm sure I can get one to work. The question is will my back work?
Greg in France (03-27-2022)
kbeachy
07-06-2016 06:42 PM
Poppyboy
10-22-2014 11:32 AM
gabrielduenas
08-23-2012 08:28 PM
