How do the Headlight Wipers Work? XJS V12
Old 04-30-2015 | 07:13 AM
orangeblossom's Avatar
Default How do the Headlight Wipers Work? XJS V12
How do the Headlight Wipers work on an XJS V12?
Do they come on automatically when you turn the Windscreen Wipers on?
Or do they only come on for a very short time when using the Windscreen Washer?
Old 04-30-2015 | 09:11 AM
Greg in France's Avatar
OB
There are two screen washer pumps. The second is so wired that it activates only when the headlights are on. When they are on, pressing the column screenwash button activates both the screen and the headlight washer pumps, and also starts the wiper motor attached to each headlight wiper arm.
The washer jets for the headlights are TINY and they are clipped onto the headlight washer arm and connected to the tube from the washer reservoir by fairly tiny black tubes. These fracture/give up, so once the pump and motors are working OK, you might have to hunt down breaks or blockages in the tubes between the reservoir and the arm jets, or even have to unblock the arm jets.
One of my sadnesses at having to fit the four headlight conversion in order to get RH dipping was that i had to remove mine. They actually are very effective when working properly.
Greg
orangeblossom (04-30-2015)
Old 04-30-2015 | 09:41 AM
OB
Greg
Hi Greg
Thanks, I never knew any of that, so before I pull the Wiper Arms off, I'll have a look and see what parts are working.
And in the event it all still works 'Splash Out' (no pun intended) for some new Wiper Blades.
Old 05-01-2015 | 02:05 AM
Originally Posted by orangeblossom
Hi Greg
OB
The arms are on fine splines. Do not just pull them as you can wreck the parts of the motor that the splined shaft is attached to. Undo the nuts on the end of the shafts, get a pair of decent pliers and place one jaw on the end of the splines shaft and the other under the arm where it goes round the shaft, and squeeze. That way the spline has no 'pull' on it. The arm will just pop off.
Greg
orangeblossom (05-01-2015)
Old 05-01-2015 | 01:17 PM
OB
Greg
Hi Greg
Thanks but although I haven't Tested it yet, everything looks all up and together apart from the need for New Blades.
So I will try and get it all working again like it should be.
JarodL
03-07-2024 01:39 AM
johnnie ryall
10-19-2015 09:44 PM
XFR_Gold
09-02-2015 12:24 PM
rmbtl2
08-26-2015 08:52 AM
Quick Reply: How do the Headlight Wipers Work? XJS V12
