How do I reattach the facelift rear bumper?
Vee,
The leading edge of the bumper cover slides into the edge of a flattened-s type strip which is probably still riveted to your car.
It effectively slots into that strip and is held through the tightness of the strip. In my experience, it often wants to pull out from that strip. After repeated episodes of it falling out, I then screwed in 3 short self-tappers through the strip and into the leading edge of the plastic bumper cover; one at each end and one in the middle. This completely resolved the problem of the edge coming loose.
Hope that makes sense. If you get under the car, you'll see the strip under the car.
Paul
Paul
Vee,
Paul
Paul
Thank you!
Tcasmarcus
08-10-2017 09:35 AM
