how do I remove the turn indicator arm from the column
Old 09-23-2018, 07:09 AM
David32407's Avatar
Default how do I remove the turn indicator arm from the column
I have a 1995 XJS Convertible 2+2...the running lights including the inside dash lights go out when I use the turn indicator. If I hold the arm just so the lights will stay on. Before I order and replace the old one I want to remove and reinstall it to be sure something just hasn't come loose.
Old 02-11-2019, 11:16 AM
David32407's Avatar
OK.....got a used turn signal stalk from Jagbits. Finally got it installed. Everything works!!!
Don B (02-11-2019)
Sarc
11-01-2018 09:09 PM
Gismo
09-11-2018 11:22 AM
kyle
08-15-2018 05:06 PM
51rover
07-20-2018 02:42 PM
Johnken
07-01-2018 05:19 PM
Quick Reply: how do I remove the turn indicator arm from the column
