How Do You Check Differential Oil Level on 90?
I want to check oil level in differential on 1990 XJS convertible.
I can't locate a plug. Rear plate is cast aluminum and has the speedometer pick-up mounted on the rear of the cover.
Do you pull the speed sensor and consider it the fill plug to check the level?
mikebaker3 (04-30-2018)
The following 2 users liked this post by 44lawrence:
Grant Francis (05-03-2018),
mikebaker3 (05-04-2018)
Grant Francis (05-05-2018)
