How Do You Test ABS Pressure Switch?
I have a 90 XJS Convertible with the Teves ABS Brakes. I have been getting both a brake light that eventually goes out and an ABS light that only goes out after about 20 minutes. Is there a test procedure?
Sometimes the light goes out with a left turn and will sometimes come on after a right turn. I want to be able to tell if it is the pump, the bake fluid reservoir, or the switch.
I would start with testing the accumulator. Allow the pump to run long enough to stop. You don't have to start the car. Turn the ignition switch off, and then press the brake pedal as many times as it takes the pedal to go hard. If it goes hard in just a a few pumps, 3-5, your accumulator ball is most likely lost its pressure. The fact that your pumps runs, most likely means that the switch, or the pump are bad. The accumulator ball is a service item. From what I understand, 5-10 years is the life of it. I also understand that the switch is a service item as well, so it might not be a bad idea to replace both as a matter of service. Have either ever been changed?
I think the main thing, is to change the accumulater ball, change out the rubber lines, and flush the brake fluid. It has only been a few years where I read how our brake fluid gets contaminated. Thats critical on these cars it seems. My fluid was literally black...
I can get you a contact for changing out that switch. It takes some kind of simple modification, but it will then take a GM switch off of a Buick Reatta I think. Maybe even a couple of other cars that make the switch MUCH less expensive. Same for the accumulator ball. It has a GM exact replacement. I paid 109.00 for mine I think. Jaguar wants 300+
Aus V8S
11-13-2015 12:01 PM
