How does A/C work
Received 10,888 Likes
As I rcall when max cool or max heat is dialed up, the system no longer looks at ambient/cabin temp.
Even if I'm not remembering correctly on that point, the pull-for-manual-control feature certainly defeats auto temp regulation.
As for the compressor not engaging....
Start with the easy stiff. Have you checked the fuses?
Have you checked the thermal fuse? Its located in the rear of the compressor in contact with the suction side gas, whose pressure drops and temps rises with a low refrigerant charge. The thermal fuse is a sealed unit containing a heater and a meltable fuse.
There does seem to be a relay under the vacuum actuator motor.
You should invest in a service manual.
philwarner
09-05-2015 10:05 AM
