How does the horn push work?
Old Yesterday | 03:51 PM
J_C_R's Avatar
Default How does the horn push work?
The horn push failed many months ago, so I rigged a push button on the ski slope to sound the horn. It works, but finding the switch really fast isn't all that easy, while pushing on the steering wheel is instinctive. So, I set about trying to fix it.
Took the steering wheel insert off today. I see that in the center of the steering column there is a copper tab, and when the insert is pushed the copper tab contacts the electrical connection in the center of the steering shaft, which closes the circuit to activate the horn.
What isn't obvious to me is how the circuit is closed. Since there is (that I can see) no electrical connection between the steering wheel insert and any other part of the steering wheel assembly, how does this system work?
Pic below.
Thanks,
John
1987 XJ-S V12
75000 miles
Old Today | 01:44 AM
Greg in France's Avatar
The horn push contacts the metal inner on that large white plastic nut in the centre of the column. If you take a wire and ground that metal inner of the nut the horn will sound. If your horn-push copper piece is not bent outwards enough from the horn push pad towards that centre metal piece of the plastic nut, then pushing the pad wil not make the horn sound. Try bending it outwards a bit so it makes better contact.
JJS- Florida (Today)
Lance 99
08-03-2024 02:10 AM
nickr76
10-21-2023 01:02 PM
Patrick 1989 XJS
05-11-2023 02:25 PM
Karel Deppe
08-27-2014 02:43 PM
Anfield Dreaming
03-20-2014 07:43 AM
Currently Active Users Viewing This Thread: 6 (2 members and 4 guests)
Quick Reply: How does the horn push work?
