How easy is it to fit a rear Anti Roll Bar and where can I get one?
How easy is it to fit a Rear Anti Roll Bar and where can I get one?
Is it just a straight bolt on, or is any drilling involved.
How much difference would it make to the handling and would it be worth it.
Does anyone have any relevant Pics that they could Share.
I don't want to go for lower Springs, or anything like that, as I can only just clear the road humps near my house.
orangeblossom (06-19-2016)
Baxtor is right.
The 4 studs, 2 each side, MAY be fitted to a 1990, my 1985 was.
Go to Grubloggers, get the sway bar. drop inks, trailing arms, "D" brackets.
Mostly PreHE XJ-S had them, but NOT all. Jaguar fitted, removed, fitted, removed, that rear bar at random throughout the early days of the XJ-S.
Makes a difference, HELL YES>
We fitted one to the S2 Daimler, oh boy, what a transformation.
I would NOT mess with aftermarket kits, thats me, no other reason, the Jag set up is good and it WORKS.
orangeblossom (06-19-2016),
warrjon (06-20-2016)
Baxtor is right.
In that case Its worth looking into, as it sounds like an easy handling fix to do.
My experience on my 91 conv with the stock 5/8" rear anti roll bar was fabricating & welding brackets to the radius arms, replaced both arm bushings, dropping the rear part of the exhaust, and I had my springs/shocks off but don't know if that's necessary for bar work, but certainly makes the job easier. I also replaced the front 7/8" anti roll bar with the stock sport 1" to get the full benefit, a whole other installation subject.
I bought my entire stock rear bar assembly used. Buying stock link pins may be a problem along with cost for the entire project. I don't know.
I would only do it again IF I picked up the entire bar assembly very cheap and had the IRS down for what ever reason. IMO I don't think the average driver would notice the handling difference maybe the firmer ride though. Just my opinion.
Lawrence
Lawrence
Received 10,916 Likes
Here's a start, but you'll still need a few bits
Jaguar XJS Sports Pack Rear Anti Roll Bar 16mm | eBay
Jaguar XJS Rear Anti Roll Bar 14mm | eBay
Lawrence
Lawrence
Definite food for thought on that.
There doesn't look much to it, except I wouldn't know how to fit it on.
Maybe this illustration will help:
Anti Roll Bar-5.3 Litre-Sportspack - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
You'll need:
-the bar itself
-brackets and bushings to mount the bar to the body
-end links, bar-to-radius arms
-radius arms with brackets to accept the end links, or weld little brackets to your existing radius arms
-bolts and nuts as needed
That's really all there is to it
It's pretty easy, just nuts-n-bolts...especially if your car already has the stud plates in the floor pan.
You'll need:
-the bar itself
You'll need:
-the bar itself
That doesn't sound too bad and so I'll start looking round for some parts.
Actually the best suspension upgrade I made was fitting the Harvey Bailey "X" frame in the front in order to control "shuttle shake" in XJ-S Conv's ,(said to be a common problem with the conv.) I don't know if that company is around anymore . It was pretty pricey , around $300.
Lawrence
Lawrence
I've never heard of one of those before, so I'll check it out.
Many Thanks.
orangeblossom (06-20-2016)
I have a Driven Man (DM) front & rear bar's on mine. Everything was in the kit & fit perfect but must mention the DM rear bar is thicker and a thicker front bar really should be considered. I was impressed with the billet link pins & bushings, but had to use big washers on all four bushing sides to make sure they stay in the link's. One bushing fell out and getting a new one off DM was a big DEAL. His rear bar included the radius arm (RA) to bar brackets that should be welded on if the car was not factory fitted you must fabricate & weld . Welding without r&r the rear RA bush could melt the bush rubber. In any case it was good time to restore the radius arms.
Last edited by 44lawrence; 06-20-2016 at 07:37 AM. Reason: forgot y on the word they
That's useful to know.
OB,
Maybe a controversial view but I wouldn't bother if I were you. I agree that it might tighten things up even on a Sportspack model, but remember that Jaguar deleted the rear anti-roll bar on late XJSs.
I think that money is better spent making sure that you have good quality springs and adjustable shocks. That will give you a perfectly acceptable rear end. If your ground clearance is low, it might be that your rear springs and shocks are already somewhat worn and a rear A/R bar is just going to slightly mask a bigger problem.
With my revised springs and shocks, and radius arm bushes fitted as per JaguarSport, I have set up the rear end on mine to what I consider is really quite an acceptable level.
Paul
Paul
The following 2 users liked this post by ptjs1:
Greg in France (06-21-2016),
orangeblossom (06-21-2016)
Penny pinchers !
Yes, Jaguar deleted it on the HE cars but perhaps realizing their mistake, re-introduced it on the 3.6 cars and, later, on some of the 5.3 Sportspack cars. Later still (as I recall) it was standard fit on the last couple years of 4.0 coupes (but not convertibles)
So Jaguar was certainly not too terribly opposed to using a rear bar.
But, you're right in that there are many other ways to get the improvements we're fater.
Anyhow, I've yet to hear from anyone who has installed the rear bar that wasn't delighted with the improvement even if Jaguar couldn't quite make up their minds whether we should have it or not !
