How I removed the fuel pump on my 96 xjs without moving the gas tank
Going to take on this project next weekend so wish me luck.
Yes, I had to unbolt the filler from the top where it mounted to the body of the car. I can't remember what pump I ordered but I'm pretty sure I got it from autozone or oreilly. Get the best pump you can find as this is not a job that you want to do twice. The biggest problem I had was that the little stands that the pump canisters go on were swollen and all messaged up from sitting fuel. I had to replace those with used ones that I bought from a member on this forum.
I would recommend using only Gates Barricade hoses. Be warned, they are not cheap. These hoses cost per inch, what you may have been used to paying per foot for normal hose.
Furthermore, the 1994 XJS will most likely use a different pump than what ICS was using. I would order from definitely look up the part number from JDHT, and hopefully that will help you confirm the cross referenced alternatives. RockAuto is one place to look.
Arnaldo (04-25-2023)
Hello everyone this is my first post!
I know its been a while since this post but I have a 1994 XJS 4.0 that's giving me low fuel pressure problems. You guys have given me the courage to attempt this repair myself and I would like to try the Walbro pump instead of the OEM. Could you tell me the model number of the one you used ICSAMERICA?
Also, In case all the hoses inside have gone to mushhh!... what type of fuel hose would be the correct replacement?... (inner diameter, submergible etc)
Thanks so much!
Thanks so much!
For the in-tank line you need to use hose specified as SAE J30R10 (this is a low temp material for in-tank use only)
Any fuel line out of the tank needs to be SAE J30R09 for pressurized lines and SAE J30R07 for non-pressurized lines (return only)
The following 4 users liked this post by icsamerica:
Thank you everyone! I'm halfway into this project and realize that as Vee indicated, my '94 uses a different pump (actually a smaller Walbro) and different mounting system to the ones icsamerica has in his photos. My pump is mounted internally in a plastic container that then has a rubber base attached to the bottom of the tank. Because of this the bigger Walbro does not fit.
Do you guys think I should try to adapt the pump to fit? I have a dremel, Epoxy and lots of zipties! 😂
The bottom of the tank. Those hooks attach to the rubber base of the fuel pump canister
The old pump actually seemed to be working but there some sort of a constriction in the fuel outlet.
bottom of the plastic fuel pump canister the rod part is the inlet (w check valve) and the filter is attached below the canister.
new and old Walbro
The old pump attached directly to the top of the canister and was sandwiched inside
Surprisingly spacious trunk, could definitely fit a few bodies 😂
new and old Walbro
The following 3 users liked this post by Vee:
The following 2 users liked this post by Arnaldo:
Greg in France (04-26-2023),
ptjs1 (04-26-2023)
#28
Adapted my new heavy duty Walbro pump to fit in the plastic canister that sits inside the tank of my '94 XJS v6. I plan to connect the fuel outlet line directly to the the pump and the return line can just float inside the tank. Should be slightly easier to access if I need to in the future
What do you guys think?
Drilled a second large hole to allow fuel to freely flow in and out of the plastic enclosure
New fuel pump is securely held inside
filter will attach to the bottom
Greg in France (05-07-2023),
ptjs1 (05-06-2023)
#30
May i step in here? So, as everything else with my jag, small problem turned big.
jaguar xjs 1992 with fuel pump similar to previous post
had fuel odor, found that its coming from evap flange, specifically from the plastic connector, one of the pins melted and previous owner just passed one wire directly through the connector by drilling hole, but he didnt silicone it.
Anyway, i found second hand flange with new connector, but the problem that the blue connector was already destroyed
no problem, went to scrape yard, found similar connector that sits tight. But i have to solder it and i should do it right with proper dielectric grease and heat shrink, for that i need to get fuel pump assmble out, but i cant remove fuel tank (ok, i dont want it, as it will brake something else) , so i moved tank as previous authors in this thread, managed to disconnect fuel lines with one hand, take the rubber base from its brackets, but cant now remove this plastic assembly with rubber mount attached.
Can someone please tell me how in hell that rubber mount sits around plastic tank assembly? can i just pull plastic assemble out inside the tank and then take it out ? or i better take the cap off?
#31
Don’t even try to take the plastic cap off inside the tank. My plastic container came out of the rubber base fairly easily… there was a big zip tie around the outside of the rubber which I snipped off and then I believe you sort of twist the plastic part within the rubber. Also keep in mind that the pump filter comes out the bottom of the rubber housing and may need to be tilted to clear the lip.
*feel free to DM me and I’ll walk you through it.
Arnaldo
Arnaldo
#32
Once you've released the rubber mounts (3) from it's metal bracket, and have disconnected the fuel lines from the pump module, you should be able to pull out the module with the isolator zip tied to it. You may have to fold in one rubber mount to get it through the hole. Definitely not a job for the weak. This in-tank design was first introduced in the XJ40 and the EVAP flange and the fuel pump module had multiple design revisions within it's short live span. I've ended up replacing the entire tank with a tank from a 1995 MY which is galvanized and used the updated in-tank sump pump design and EVAP flange also first used by the X300. Imho, this was a ****-pour design and ease of service was obviously not high on Jaguar/Ford's priority list. If they would've stuck with the pre 1992 MY external search tank design, galvanize all the metal parts and add an internally mounted fuel pump to the surge tank, this could've worked out better.
#33
oh my gosh, thats was hell of a job, just fixing the connector tuned to a whole week nightmare, i should have removed the tank ) Anyway, now its all done but i cant get flange to sit in the rubber mount, it just wont, im really pissed and will get back to that after couple of days of beer and beach.
Thanks everyone
Thanks everyone
