How much leakage makes a cam cover gasket worth changing?
I've got the gasket and I've got a leak. However, in the course of another thread it was suggested that I might not need to check it. It is definitely seeping at the gaskets and there was a slight hint of oil in my plugs (especially #6). However, it hasn't been enough that it has dripped to the floor and I haven't noticed any appreciable usage in the month/~500 miles I've had it.
Any leak bothers me so my first instict is to change but then part of me says if it's working well don't fiddle with it.
So, change the gasket or leave well enough alone until it becomes more of a problem?
TIA,
Tony
TIA,
Tony
It's done. Ended up changing them. When I loosened to re-torque I lifted up the cover a bit to take a look. The gasket was cracked in quite a few placed. Changed it out along with the half moons (with black rtv) and the plug ring gaskets. Looks good so far. Going to go for a little drive in a bit to check to see if I got them down good. The spec (as it turns out after checking the manual myself) is only about 10 Newton meters. Did the back and forth and around tightening to make sure it was equally seated.
xjrjag
10-27-2021 11:48 PM
