How much power should the ABS solenoids require?
Hey guys,
Does anyone here know how much power/current the Teves ABS solenoids require to properly operate? I can't see it needing like loads of amps and the full 12V. Probably only less required. Probably like 6V (4x AA battery) and that would be enough to test the function... Or am I thinking a little on the loose side?
Damien
Damien
They vary between 6 and 9 ohm. I was surprised as I found continuity between all of them... But then again, they don't all activate a once... Am I thinking that somewhere aroud 6V (4 AA) might just be enough? Or should I be looking at a little block battery? I want to be able to check them and keep them open/closed for a second or two without worrying about burning their coils...
Steve.c3h8
02-29-2016 07:20 AM
rscultho
09-02-2011 07:29 AM
