How to open the boot without a key
orangeblossom (06-05-2019)
Scott,
Have a look on the parts diagram on the Jaguar website and you'll see that a rod connects the boot lock to the boot latch. A carefully drilled small hole just off centre behind the number plate and you should then be able to use a bit of wire to pull the rod and activate the boot latch.
Good luck
Paul
Good luck
Paul
OK then try this get the original key numbers and history of your car.
https://www.jaguarheritage.com/archi.../certificates/
or this for the trunk boot lock
https://www.ebay.com/sch/i.html?_fro...coder&_sacat=0
Jagisbest
06-03-2017 12:25 PM
MrJagXJ
09-15-2013 06:32 PM
therobesons
01-08-2012 08:22 PM
