How to remove door panel and rear panel
Front door panel: proceed as follows:
Greg
- Disconnect battery
- Open door and unscrew from the door front end the chrome striker plate that operates the courtesy light switch
- ease back the chrome ferrule that is round the thin end of the armrest. Under this is a HUGE pozi screw that you must undo
- under the door pocket front end is a well hidden screw, undo it
- then go round the door car and pop out the trim clips that hold the card edges in place. Start at the bottom front and work up the front vertical edge to the window, then go along the door bottom and up the rear edge to the window
- the car is now held in place by a large clip in the middle and by the edge along the window bottom. A GOOD vertical upward sharp clonk with the base opf the hand on the card will pop these free. CAREFUL as the door card is attached to the speaker wires and the courtesy light wires, AND in your case it being the driver's door the mirror switch wires.
- disconnect these carefully at their plugs. Get someone to hold the card while you do this as you will need two hands.
- remove rear seat bottom (held by two screws under the front edge)
- remove seat back (held by screws at the bottom and top at the side)
- this allows the side panels to be fully seen; If the leather runs round the door opening, then pull off the furflex on the back edge of the door shut, and carefully peel back the leather to reveal fixing screws
- also fixing screws at the top rear of the panel
- a sharp upwards push should then loosen off the panel from the top edge where it is pushed into the bodywork.
Greg
The following 3 users liked this post by Greg in France:
Just to add that on late convertibles, they use the "fir-tree" push hidden clips, rather than screws to hold the trim on the b-post. you can usually feel where they are. It's easier if you remove the door tread plate as the trim tucks under. From memory, I don't think you have to remove the door furflex either (but I might be wrong!). It's easier to have the seat base out, but I think you can leave the back in lplace if necessary. There's only one clip on the top part of the trim panel which I thinm is also a spire push-type.
Good luck
Paul
Good luck
Paul
Hi,
I just wanted to thank everyone for their perfect instructions on how to remove the door panels. The speakers went in fairly easily. Tomorrow I wire up the amp and sirius radio. The stereo will sound almost as good as the car drives!
I am using all Alpine equipment.
Head Unit CDE-HD149BT
Front Speakers SPR-60C
Rear Speakers SPR-60
Amp MRV-F300
Jomo
Amp MRV-F300
Jomo
Rhett (08-22-2014)
The Alpine is a really easy install - you can even use the same mounting brackets and screws. I put an Alpine in my '95 some years back. You'll have to match wires but again it's easy. Re the Sirius (I had as well) to keep from drilling holes anywhere use the bracket with the double sided tape and stick it to the veneer panel between the clock and the right hand switches.
99xk8guy
06-05-2023 06:28 AM
davidladewig
09-03-2015 06:32 PM
