How to: Replace bulb behind trip comp/clock
Old 08-09-2012, 10:59 AM
DenverDRS's Avatar
Default How to: Replace bulb behind trip comp/clock
The light behind the trip computer/clock on my '93 does not illuminate. I'm hoping it's a simple bulb replacement. Anyone have any info on the procedure?
Greatly appreciated!
Old 08-09-2012, 01:31 PM
Sarc's Avatar
I'm assuming your problem is actually the bulbs...... (and not something wrong with the circuit, or the dimmer, etc, etc)
There are 2 bulbs (from memory) on the trip computer.
To remove it, you first need to remove the 2 sets of switches on either side of it. These just pull out of the dash by pulling the wooden trin piece off. Then, reaching in through the holes in the dash (where the switches used to be) there are 2 small bolts holding the trip computer in. Loosen these then the trip computer comes out the front of the dash. It's been a while since I did mine so I can't remember if the bulbs are mounted directly on the back (like you see with an instrument pod) or if further dis-assembly is required
Old 08-09-2012, 01:51 PM
DenverDRS's Avatar
Default Thank you
I appreciate the instruction. The lights behind the peripheral buttons illuminate, so I'm hoping a bulb replacement will remedy the matter. I'll replace all bulbs once the removal is complete.
Old 08-10-2012, 07:02 AM
Vee's Avatar
Vee
Vee is online now
Received 1,575 Likes on 1,223 Posts
I replaced mine with LEDs. You will need to buy something to correct the change in light, which I did as well. I used a colored gel, like for a stage light.
The amount of heat the standard bulbs gave off was too much.
You will need two NEO5 bulbs.
You have to pop off the buttons on either side of the trip computer to access the 8mm bolts keeping the trip computer in. Once you get those off, the bulb replacements was pretty straightforward.
Again, I would recommend LED, and a saffron color light gel from an art store. It's an orange-ish color. That will convert it back to the turquoise-y light color.
Old 08-15-2012, 02:34 AM
JagVilly's Avatar
has anyone tried changing the bulbs on the switches located on either side of the trip computer?? mine seem kind of dim.
Old 08-15-2012, 07:04 AM
Vee's Avatar
Vee
Vee is online now
No, I did not try. There are two small bulbs (that can probably be replaced with something from radio shack) that will need to be soldered on.
Be prepared to buy some kind of glass paint to paint the bulbs. The buttons will not match the display if you change them out with LEDs...which is the only way to go if you're going through the trouble.
Michael's craft store sells this type of paint. I believe "Saffron" is the color you'll want.
PMKimpton
08-03-2019 08:22 PM
KarimPA
09-03-2015 07:32 PM
dcvickers
09-02-2015 06:14 PM
OkieTim
09-02-2015 12:48 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: How to: Replace bulb behind trip comp/clock
