How to: Service the V12 power resistor
Great info Greg. Thank you.
Mate I have an electronic background (not automotive though) and was curious if you knew or anybody else knew, exactly what is the "power resistor" pack.
In electronics, we sometimes use "power resistors" in current sensing circuits. They are physcially larger in nature than typical 1/4W resistors you might see on a circuit board as these "power resistors" are so designed to disapate a fair bit of heat.
Anybody know whats going on inside that box just out of interest sake?
I dont wanna smash mine open to find out
The ECU supplies 12v to the injectors through the resistors for the full duration of the injector pulse. The initial short duration "OPEN" spike is sent on separate wiring directly to the injectors without passing through the resistor pack.
At idle you can disconnect the resistor pack completely and the car will continue to idle. I'm not suggesting it, when I accidentally did the adrenaline rush was surprising. It was fine. The initial "open spike" is apparently sufficient for idle fuel requirements.
paulyling (07-05-2017)
The ECU is wired in Peak and Hold with outputs for Peak and separate outputs for hold which go through the resistor pack.
The injectors in the V12 are about 1.6ohms (R) each and are wired in parallel in bundles of 3 so the resistance is actually 0.53ohms and the current the ECU has to supply is 22.6amps now if the ECU had to supply this current for the time injectors were needed to be open then the heat generated would be significant.
The resistor pack is a current limiting device designed to limit current I=E/R
trosty
26
12-18-2022 06:40 PM
