How Should they Test the Hand Brake on an XJS for the MOT
I'm not exactly 'Over The Moon' with the way that they Tested the Handbrake on my XJS for her MOT as when they applied the Handbrake on The Rolling Road the Torque was such that it literally tore the Hand Brake Pads from their mountings
Which as many XJS Owners will know are Tiny in comparison to those on other Cars
No such problems with drum brakes but I do not feel the Handbrake on an XJS is of the type that is suitable for being Tested on a Rolling Road, as for one thing in order to fix it, I will very likely have to drop the Cage and then who knows the very same thing could easily happen again on another occasion
I seem to remember reading somewhere that where a Vehicles Handbrake is unsuitable for Testing on a Rolling Road, the alternative would be to have the Vehicles Handbrake Tested on an incline
Does anyone know if I have the right to insist that the Handbrake was Tested on an incline rather than the Rolling Road which tore the Pads from their Mountings and also does anyone know if Jaguar have a procedure laid down which I could then use to back this up
As in my view the Handbrake should be Tested to hold the Car on an Incline, rather than subject it to the excess Torque of the Rolling Road, which in this case destroyed the Pads altogether
Has anyone else had this problem, or is it just me?
orangeblossom (12-06-2020)
Hi Brinny
Cheers!
I don't think it ever crosses their mind what damage can be done on that Rolling Road Test and though I'm straining at the bit to mention this during the MOT, I think some may agree with me that Two People in Life that you never upset are your Dentist and MOT Tester
Although not necessarily in that order
Cheers!
OB,
I'm really sorry to hear of the problems you've encountered. Is this an MoT station that you regularly use? I'm always at pains to point out to anyone intending to put my XJSs on a rolling road, that they have mechanical Limited Slip Diffs. Most places then decide that they won't use the rolling road and use a Tapley meter instead.
Depending on the damage, you may be able to fit new pads without dropping the cage.
BUT, if yiou really have to drop it, see it as a great opportunity to refurbish the brakes cage, mounts, suspension, radius arms, maybe even the diff! There's always a silver lining!
Good luck
Paul
Good luck
Paul
Received 10,979 Likes
The handbrake calipers can be removed without dropping the cage. I've done it a couple times, most recently just a few weeks ago. It's not terribly difficult; more of a PITA....if you get the distinction.
Some here (Greg?) has an excellent write-up on modifying the handbrake pads so they don't come apart.
I've always considered the handbrake on these cars to be a "parking brake". Not an "emergency brake".
Hi Mac
I did Test the Handbrake myself before I took her for her MOT and while I was quite satisfied that it was working 100% in the UK the MOT Tester has to Test it as well and this has to be done in accordance with the the laid down procedure in the MOT Testers manual
Which unfortunately seems to include a Rolling Road Test, where those tiny little Brake Pads, were probably not designed to handle the kind of Torque they encounter during the Rolling Road Test
As it is after all a Parking Brake and not a Secondary device that should be used as an alternative to the Foot Brake
Hi Paul
Really glad that you chipped in as always and yes this is my Goto MOT Station and though they know the Car has LSD they always do the Test on the Rollers regardless, assuring me that all will be ok
Though being as paranoid as I am, that kind of reassurance just falls on deaf ears and hope they are just as willing to buy me a new half shaft if they break it, although I somehow think not
I have also had the Test done at another Garage with the Gadget that you mentioned, although for reasons i'll keep to myself I certainly won't be taking my Car there again but as for now I'll have to see what damage has been done before I then decide on my next move, though anyway Thanks for your help
Alex
Alex
Received 1,236 Likes
XJS handbrake is the worst engineering is a !joke.
OK when i was unloading my 1978 XJS from a rollback truck, car started to roll backward to fast so reaction i pulled the brake !
lot of noise under car and car stopped at bottom of ramp!
let off brake car would not move ,driver said better step out and SEE this!
the whole rear IRS subframe had RIPPED the mounts loose and was jambd cattiwaumpass side ways!
at that point ,sorry, i had some reservasion about Jag designs!
had to jack up the car and tried to lower it back on rubber mounts , so we could move the car into garage!
i was NOT a happy guy!
ron
ron
Hi Mac
What is a MOT.
Damn Englishter testers. LOL
macdoesit,
All cars used on the road in the UK and younger than 40 years old have to pass an annual MoT (Ministry of Transport) test.
Similar to roadworthiness tests in other countries, it checks a defined list of items from structural integrity, brakes, lights, seat belts, steering, vehicle engine emissions etc.
Paul
Paul
orangeblossom (12-07-2020)
Once the axle is out of the car, it is an easy day's work. The only non-garage thing you need help with is asking your local machine shop to deepen the slot in the calipers that the pads go into by a few mm.
The handbrake on my car will stop the car, in gear, from 15 MPH no bother. Also it has so far survived three French MoTs where they use a rolling road and have a higher efficiency threshold than the UK version.
The following 4 users liked this post by Greg in France:
The following 2 users liked this post by ronbros:
orangeblossom (12-07-2020),
TobyJag (12-10-2020)
scrible
10-24-2012 04:03 PM
