HVAC vacuum resivior lines
So I just found a line off at the resivior. I have two connections...one going towards the console and the other is has about 12 inches of line connected to nothing and not capped. I can't find a vac routing diagram for the HVAC. Anyone know where these two go? Looks like vac is supplied through a third rubber line that comes out under the brake accumulator and isn't connected directly to the resivior but to the HVAC unit.
Air Conditioning Vacuum Tank and Hoses - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
Greg
wesmc (07-11-2014)
So I don't have another connector open off the rear of the intake. I have a small red vac line going to the ignition ECU (prolly not on an 85,) a large black one you describe not on the resivior going to a check valve to intake , and one from the resivior to nothing. Wonder where the other vacuum line should be? I don't see anything open.
Greg
