I fixed the no start but now a new issue... video inside
Once again thank you for all the help everyone! So here it is, the magnetic pickup was toast and wouldn't start. Now it starts but once the throttle is touched it wants to die. If I hold the throttle it will rise the Rpms a bit but clearly you can see not fast or good. Tps is putting out .28-4.78v nice and smooth from closed to open. It was .38v but dropped to .28v.... not sure what my fuel pressure is at but I do know this dummy fixed his gas tank leak and cleaned it out but never bought a new fuel filter... so what should I be looking into besides clearly a fuel filter? Vacuum leak? Bad timing? I cleaned and tested all injectors. I built the new harness and seems to be firing all cylinders.
