I have checked all vendors here.
The "crimps" are not crimps, they are a collar that is not attached to the hose and are reusable. Fuel injection hose of the right size can be cut to length and used.
The type of fitting used on the rail and the hose is a system that is designed to be leak free with no clamp, using a clamp will actually compromise the joint.
When removing the old hose UNDER NO CIRCUMSTANCES use a knife lengthwise to split the old hose. The blade will often go through the hose and nick the barbs on the rail or injector. These nicks will cause leaks.
The following 3 users liked this post by Jagboi64:
macdoesit (11-21-2017)
https://www.jaguarclassicparts.com/u...tors-5-3-litre
Or try V12 Performance. Small business, sometimes takes some time.
Jaguar XJS V12 Fuel Injection Hoses and Kits for V12 Performance
As you are in the UK, I suggest these people, who supply a full kit with instructions. Very high quality stuff.
https://mrinjectoruk.co.uk/Bosch-028...-P2420447.aspx
and this
https://mrinjectoruk.co.uk/Jaguar-V1...-P4886461.aspx
These two enables a full refurb of the injector, its filter, all its seals and pintles.
They do kits for the 6 cylinder engine as well.
The following 2 users liked this post by Greg in France:
macdoesit (11-21-2017),
someguywithajag (07-30-2018)
Brinny
and this
and this
Notes made Greg . Thank you
Oh yes, they are not easy to remove! What I did was use a sharp hobby knife to shave down the old hose until it was very thin on the side and then it could split and come off. Takes patience to do, it won't be a quick process.
I cut the injectors off and burnt the stubs on the rail with a gas lamp the injectors i bent the collar down and used a blade to split them.
I googled it and came up with 4 usa supplier's and same uk. One in Texas which I have used in the past for twin fans.
Pay close attention to the orientation of the injector hold-down plates. Installing them backwards will darken your day a bit.
Order new injector seals ahead of time...the ones that sit in the inlet manifolds
I'm on my first cuppa coffee. Might come back with more.
macdoesit (11-22-2017)
Yes, remove the rail.
Does the kit (Greg in France) post have all the parts needed ?
