I have cooled off a bit
I stepped away from the Jag about a week and ready with a new attitude.
Same problem as in another thread (HELP,HELP,HELP) and will start new.
What I want to do now is take the distributor cap and rotar off for inspection.
Will someone tell me what all needs to come off to get the Distributor cap off ?
Thank you for any info.
To get the cap off you need to remove the ignition leads, then undo the 3 screws holding the cap on and it will come off.
Rotor is also held in place with 2 screws. Rotor will only go one one way so you can not get this wrong.
Original Marelli caps have the cylinder number on the cap (1A 1B etc) but some aftermarket caps do not.
Keep in mind that the ignition lead positions on a Marelli cap are not the same as a Lucas.
macdoesit (08-27-2017)
So I can get to it without removing anything else, looks awfully tight in there.
The cruise does not work so can i remove the bellows without messing anything up and discard bellows.
Received 2,399 Likes
Should you so choose, the bellows might be repaired. They develop leaks at the ends. Add a sealant and clamp down. I've never gotten around to replace mine. Heck, I'm not sure it worked from the time circa 2001 that I got my car..
Caveat. Take pictures or make sketches or both before taking it apart.
Carl
Carl
If you need a new cap, SNG Barratt carries a high quality reproduction made for them. The original Marelli caps are no longer made, and NOS might be so old that it could be prone to failure.
macdoesit (08-28-2017)
macdoesit (08-29-2017)
