I want 13" brakes where to start?
I know i don't necessarily need brakes this big, but i want them, to fill the whole wheel and give the car the aggressive look, so i was thinking:
wilwood drilled and slotted rotors
6 Piston calipers
and most likely custom brackets
Anyone have any suggestions?
6 Piston calipers
For purely aesthetic reasons, 6 piston Wilwood calipers would be nice! Whatever you do, see if you can get a caliper with dust boots around the piston. Also, make sure you have both the height/diameter AND depth inside the new wheels to accommodate the larger caliper.
If you're interested in the rear brake upgrade, you can upgrade to vented rear discs for about $400. They would certainly handle a more aggressive pad material with more grace. The catch is, you have to install new rear rotors, which is a pain unless you're dropping the IRS anyway. Pics and info on my website here:
Dave's Jaguar XJ6 LS1 Swap
Received 1,236 Likes
cal i have installed many types and makes of cylinder sleeves,(never Rob Beere tho), in the past 50yrs.
my personal favorite today are the DARTON type.
but be aware that it really is up to the machinist and his abilities,plus experience level.
i dont think anyone on this site who has installed R/B liners, especially 96 bore pieces!
but i'm sure that XJR5006 has or knows much about it!
OOPS wrong thread, i thought it was the sleeve thread!!??
if you really want to stop ,a local Mustang guy has 15" front rotors, and 13" rears, 6 piston calips.
Wolfy
05-28-2024 08:06 AM
