Idle finally @ 750
I have to use an * though. I did it with a very minor mod. It is evident my AAV isn't working correctly. I used very thin, high temp aluminum tape. I covered the hole within the air filter housing. You can within 2 minutes use a pin to increase idle speed if needed in the cooler weather. I'll work on that AAV in the fall. It is a different car @ 750 idle for sure.
Received 10,908 Likes
Flint Ironstag (04-23-2014)
You're gonna make me CONFESS? How cruel!
I tried the same thing on a V12 once.....blocking off the inlet to AAV. And the end result was a distributor full of oil. Took a couple days. It wasn't my car either. I was trying to save a "I'm tight for money" guy $300 for a new AAV.
No good deed (or poorly conceived plan) goes unpunished :-)
I re-routed the distributor vent to the back side of the air filter housing. All's well since then.
Just noticed a guy on E-bay offering to rebuild your aav for $70 us. Seller is my1 bugs. Send him yours, he rebuilds and ships back. Mines totally dead, and when I get the extra funds, Ill try it out! Parts are getting scares, expensive, if someone comes up with a service that helps us, Im gonna give them a go around!
