If You Need Spark Plug Wires
Two days ago I ordered the Denso 8mm wires from Amazon. Believe it or not they were only $7.04, and before alerting everyone I wanted to receive them and make sure there wasn't some mixup or problem. Doesn't seem to be any issue with them that I can see and I'll install them this weekend.
Just checked and there are still two left in stock, but the price has jumped to $13.97 which is still a bargain.
Good Luck
Good Luck
Received 10,871 Likes
Just an update, I installed these this weekend.
Since the old wires had nice labels with 1A, 1B, 2A etc. I thought it would be easy to match the new unlabeled wires to the old to determine placement, but alas no they didn't match up. However, if you follow the wire routing outlined in this TSB:
http://www.jagrepair.com/images/TSB/...%20Misfire.pdf
They work quite well.
