Ignition Coil Casing Cracks
I would consider that as a break in the insulation that isn't necessarily going to cause a problem unless something conductive gets down the hole, i.e. water or oil. If one starts shorting to ground, you will know it.
Normally I would take this opportunity to shamelessly offer to sell you good used ones, but I've seen new coils for sale around the ether for like $70.00 each. I have one new one if that helps, but it sounds like you're doing fine as is. PM me otherwise.
scooternva
20
09-27-2023 11:25 AM
