ignition coil and leads
One of the ignition coils on my 95v12 failed. On inspection. It seems that the electrical outlet is only on the bottom of the HT socket. Hence the standard ignition leads do not make a solid contact. Should the proper leads have some spring or such to ensure an electrical contact between the coil and the lead ?
