Ignition harness
Ignition harness
I am looking for the ignition harness (wiring, loom) part number. This loom connected near alternator then to ignition coil, AC compressor, oil pressure, kickdown switch. I think it suitable for XJ12 5.3L, XJS V12 5.3L Lucas ignition.
And where can I buy this harness?
I spent two days searching, google, Barratt, Limorа, Welsh, JCP no luck.
Nicolay
I think it look like on the picture.
Nicolay
Hi Greg. This is number 3 on the illustration DAC5895 for XJS V12 5.3L Lucas ignition.
I was find service bulletin
How I see the injector harness is same XJS V12 and XJ12.
The engine harness is different.
And now available with aftermarket parts numbers
DAC2391 is XJ2311
DAC3718 is XJ2312
DAC2690 is XJ2313
DAC2689 and
DAC5895 is XJ2431
MEDIUM BULLET CRIMP SET WITH TOOLS PART NO: 103-112 https://www.autosparks.co.uk/finder
DAC2391 is XJ2311
DAC3718 is XJ2312
DAC2690 is XJ2313
DAC2689 and
DAC5895 is XJ2431
Greg in France (02-19-2019)
To be honest, my advice would be to find a decent auto-electrician and have them make a new one for you, copying the original. There's nothing difficult about it, as they are just connectors and wire - personally I would DIY it, but you may prefer to get someone else to do it if it's not your thing.
xjsv12 (02-19-2019)
runerk
08-14-2015 08:26 PM
tcpoland
12-22-2013 03:19 PM
