Ignition Short
Ignition Short
I shorted out a wire in the ignition system, It will turn over but not start. Im thinking maybe it's the Crankshaft Position Sensor, but I took a diagnostic scan ands it shows everything is good.. I would think it would throw a code if it were the Crank Sensor..Thanks for any help...
Thank you for that clarification.
The CAS probably has not had time to throw a code. My X300 AJ16 drove home, stopped, went to restart an hour later, nope. NO codes, nothing.
Since it was at that 160K magical number, the CAS was 1st suspect. Borrowed one from next door, all sweet.
Which wire did you short??
I dont have a schematics for the XJ-S with the AJ16, but the X300 has a number of Ignition fuses, and relays, maybe one of them has popped.
If you have a volt meter, probe the Red wire of the CAS, with Ign ON, it should have 12v. That will eliminate some of the fuses etc.
OK,
Bonnet open
Lean over the RH side,look at the front corner of the engine.
There is a metal (tin) lid with a window in it facing you. That is the CAM angle sensor.
Down the front of that, and SLIGHTLY towards the centre of the engine timing cover is a vertical loom connector.
Follow the wires DOWN from that connector, and you will reach the CAS.
It is mounted on a bracket that is bolted to the timing cover. MEMORY????? 8mm spanner size.
That vertical connector is a problem in that the openings of it are vertical, and rubbish/oil etc falls in there, and the terminals loose their integrity, dead engine.
I have an R here at the moment, and I will see if I can get some snaps. not much room under that sucker. I will be back.
Bonnet open
"SNAP!" sounds more like something taking too much current and expanding until something gives.
An appropriate wiring schematic helps find the wires ends quickly. Same process regardless...
Do you have power to a component where you should?
If no, trace wiring back towards the source.
Do you have power at the other end?
And repeat...
e.g.I shorted the thermoswitch leads on my 5.3 and killed something. Every in-line and boxed fuse checked out. Cleaned all joins and holders and still nothing. Apparently the copper traces on the board inside the Diode pack (looks like a relay in the efan circuit ) are rated at less current than the fuses! I would never have found this break without metering the circuit at each junction. Power went in, but did not come out of the diode pack.
This probably what you are looking for.
https://www.jaguarforums.com/forum/x...ams-faq-34887/
Found it in the top section of the XJS section, under the "How to quick links".
Scroll down few, and you will come to "forcedair1", who has a 5.9mb wiring diagram that should fit.
Send him a PM with your private email address, and he will send it to you.
Grant Francis (07-05-2017)
