Impossible to change gear from "P"
It's most likely the "Gear Shift Interlock". It prevents you from shifting into gear if you don't step on the Brake Pedal first. The Brake Light Switch is not making the connection when you step on the brake (prior to shifting out of Park). Try tapping the Brake Pedal or tapping it sideways a few times. If the switch is completely gone and you need to move the car, try this fix.
hen555
09-07-2015 11:13 PM
