Injector Bung Welding Service?
Received 1,236 Likes
i have done that procedure a few times, on other engines.
be sure you have the rails and couple injectors that you are gonna use, so you can make sure of the angle and injector position is correct.
and as far as heat warp ,you should resurface the manifold to head surface, just to be sure it wont leak air.
on mine i also had the plenums and runners EXTRUDE HONED, for a smooth air run, and i , thermal coated the piston tops, complete head surface, all valves ,and most important the long exhaust ports,not inlets.
FS[SouthEast]: X300 XJR engine & misc parts
knightofgold
02-11-2016 06:03 PM
