Injector flow rates
Leo
The injectors fitted to the 5.3 are Bosch 0 280 150 023 (also known at the time as Lucas 73178A).
The attached link goes to a chart that shows the flow rate for this injector at 3 bar (remember it runs at 2 bar in the engine). It is the 8th line of data line on the chart.
InjectorRatesBosch
Greg
InjectorRatesBosch
Greg
I have the 5.3L HE listed as 0 280 150 163
Greg in France (01-28-2019)
https://mrinjectoruk.co.uk/Jaguar-V1...-P3260395.aspx
warrjon (01-28-2019)
So Greg, an 90 Marelli would also have the 16CU ECU? And to adjust do you know which way you turn the adjuster to enrichen or lean? I.E. clockwise or cc to affect the mixture. Interesting discussion BTW. I haven't had any time to test my O2 sensor voltage yet, but banking this knowledge for now.
ronbros (01-30-2019)
Bosch injectors 0 280 150 161, 162, 163, and 164 are all identical spec-wise. 161 and 162 ( short & long hoses ) are listed as “Production Stop” and supeceeded by 163 and 164 ( long and short respectively ).
Greg in France (01-30-2019)
Gasoline is .75 g/cc. I flipped that conversion. 191.1 cc/m @ 43.5 psi is correct. Sorry to confuse the discussion with that error.
#28
Received 1,236 Likes
about adjusting idle fuel mixture,, again i'm kinda old fashoined!
get an old/new vacuum gage hook it into the inlet manifold ,either side , get the engine up to normal operating temperature!
then slowly turn the control ,both sides of vacuum dropping off, and then turn it to a middle position, vacuum should rise up and find a happy medium(highest vac.),!
at that point the engine is happy as its gonna be!,,altho some times in cold weather a slight tweak to the rich side makes engine more comfortable!
HAPPY ENGINE = happy owner!!LOL.
ronbros (01-31-2019)
WaterDragon
10-30-2012 12:42 AM
WaterDragon
10-16-2012 10:29 AM
