Injector flow rates
Old 01-28-2019, 03:30 AM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
Leo
The injectors fitted to the 5.3 are Bosch 0 280 150 023 (also known at the time as Lucas 73178A).
The attached link goes to a chart that shows the flow rate for this injector at 3 bar (remember it runs at 2 bar in the engine). It is the 8th line of data line on the chart.
InjectorRatesBosch
Greg
33.5lb seems very high for a 5.3L V12, the 6.0L uses 19lb.
I have the 5.3L HE listed as 0 280 150 163
Greg in France (01-28-2019)
Old 01-28-2019, 04:09 AM
Greg in France's Avatar
Received 9,330 Likes on 5,475 Posts
Warren, you are correct, that number is listed on the table too. I have changed my post above. Mr Injector agrees with you! Many apologies Leo
https://mrinjectoruk.co.uk/Jaguar-V1...-P3260395.aspx
warrjon (01-28-2019)
Old 01-29-2019, 09:04 PM
Fla Steve's Avatar
Lee
Just in case you did not know, on the 16CU ECU (which you should have) there is a trim adjuster to richen or lean the engine, which can be used to make it happy at tickover.
Greg
So Greg, an 90 Marelli would also have the 16CU ECU? And to adjust do you know which way you turn the adjuster to enrichen or lean? I.E. clockwise or cc to affect the mixture. Interesting discussion BTW. I haven't had any time to test my O2 sensor voltage yet, but banking this knowledge for now.
Old 01-30-2019, 01:02 AM
The ECU for the Marelli is also a 16CU. I have forgotten which way enriches, but you can easily hear the engine note alter and get more or less comfortable.
ronbros (01-30-2019)
Old 01-30-2019, 03:34 AM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Try this.
File Type: pdf
Old 01-30-2019, 06:09 AM
JigJag's Avatar
Bosch injectors 0 280 150 161, 162, 163, and 164 are all identical spec-wise. 161 and 162 ( short & long hoses ) are listed as “Production Stop” and supeceeded by 163 and 164 ( long and short respectively ).
Greg in France (01-30-2019)
Old 01-30-2019, 06:17 AM
JigJag's Avatar
Originally Posted by leo_denmark
Fuel density must be less than 1, so I think you might have inverted the calculation ?
if that is the case, then the result is 191.6 cc and thereby not that far off.
It seems 3 bar is the default pressure for these measurements.
Gasoline is .75 g/cc. I flipped that conversion. 191.1 cc/m @ 43.5 psi is correct. Sorry to confuse the discussion with that error.
  #28
Old 01-30-2019, 05:46 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
about adjusting idle fuel mixture,, again i'm kinda old fashoined!
get an old/new vacuum gage hook it into the inlet manifold ,either side , get the engine up to normal operating temperature!
then slowly turn the control ,both sides of vacuum dropping off, and then turn it to a middle position, vacuum should rise up and find a happy medium(highest vac.),!
at that point the engine is happy as its gonna be!,,altho some times in cold weather a slight tweak to the rich side makes engine more comfortable!
HAPPY ENGINE = happy owner!!LOL.
Old 01-30-2019, 11:53 PM
leo_denmark's Avatar
Higher vacuum must simply be equal to higher RPM ? Meaning you could do the same just by keeping an eye on where RPM peaks ?
ronbros (01-31-2019)
  #30
Old 01-31-2019, 12:09 PM
ronbros's Avatar
provided you have an accurate rpm gage , BUT why not have both methods. LOL.
myself i use my ears also, surprising what a body can do!
ron thx
al_roethlisberger
04-07-2018 09:52 AM
Daim
07-02-2016 08:04 AM
Jagboi64
07-05-2014 01:31 PM
WaterDragon
10-30-2012 12:42 AM
WaterDragon
10-16-2012 10:29 AM
Quick Reply: Injector flow rates
