Injector issues...................our just partial (hopeing) information
Old 09-15-2019, 11:15 AM
anyoldiron's Avatar
Banned
Originally Posted by Grant Francis
This pin out I scribed years ago has saved me hours of "what the hell", and to probe each connector and the other end in the engine bay is not that hard.
Thanks. Which way is ''top''? When counting pins left to right or right to left?
Thanks AOI
Old 09-15-2019, 11:18 AM
anyoldiron's Avatar
Banned
Default Wot, no spring...................?
So , having opened the ign carefully i seem to have no spring...................................how do i 'hot wire' it so i can eliminate this as a problem?
Old 09-15-2019, 11:15 PM
Received 10,544 Likes on 6,964 Posts
OOPS.
I wrote this years ago, coz I forget stuff.
You will need to joint Brown to White, then flash White/Yellow to start. SIMPLE.
anyoldiron (09-16-2019)
Old 09-16-2019, 04:21 PM
anyoldiron's Avatar
Banned
Default ''lts life Jim but not as we know it, not as we know it''
......................well, thats not exactly true.
1, l cleaned the ign switch as that was suspect, no change.
2, l removed the cruise control unit and wiggled the two suspect wires.........................spark and pulse return.
So, another problem IDed. lm going to rewire that section.
Currently changing plugs curious to see what works when im done with that.
Cheers AOI
Grant Francis (09-16-2019)
Old 09-16-2019, 09:31 PM
Thanks AOI
Dont remember.
There a SMALL numbers on either the rear of the plug, or the ECU, I would never see them these days.
I used the ORANGE wire in the plug as the ID key, as it goes to Pin #15, and then counted off from there.
Lower row is 1 to 19, Top row is 20 to 35.
#18 is lower LEFT looking into the ECU. It is a White/Slate wire, SAME colour code as the Tacho wire out of the AB14.
anyoldiron (09-17-2019), Greg in France (09-17-2019)
Alan E L
08-20-2019 05:12 PM
layada
01-10-2017 02:18 PM
EcbJag
01-27-2015 01:39 AM
Mypantera
05-02-2012 07:09 PM
M90power
03-24-2012 08:35 PM
Quick Reply: Injector issues...................our just partial (hopeing) information
