Injector signal
MS only needs a tach signal. That can come from a set of points, a hall sensor, a VR, or other signal that determines engine speed. There is no crank or cam sensor needed.
The Jag ECU picks up its tach signal from the ignition amp and feeds it to the ECU on pin 16. There is no crank position sensor.
Collector1
09-28-2015 03:52 AM
