Inner fulcrum shaft Help
The key is getting the so called "dog bone" casting that bolts up to the side of the diff exactly aligned with the cage holes. Any misalignment is the reason the shaft will not go through.
One way to go about it is to have some horseshoe-shaped shims, then loosen off the casting a touch and thread the shaft through everything - which should be easy. Then gradually tighten up the casting fixing bolts, frequently testing the shaft b y pushing it in and out a short amount, to see if it is binding. If/when it starts to bind, insert a shim to hold the casting at the free point, and continue like that.
The bearing bits should stay in the wishbone eyes, proving they are glued up with some stiff grease.
Greg
Greg
The following 2 users liked this post by Greg in France:
Doug (04-14-2017),
Grant Francis (04-15-2017)
Received 10,871 Likes
The following 2 users liked this post by Doug:
Grant Francis (04-15-2017),
Greg in France (04-14-2017)
I gave everything a liberal coating of grease. that holds all the washers in place. Start at one side and slide the shaft though, then move to the other side and side all the greased washers etc in place. You might have to pry back the cage to give enough space, but it will go. The grease holds everything in place, and I also used a tapered punch to get everything centered.
The shims are item #6 in this illustration. The 'casting' is #5
https://www.jaguarclassicparts.com/u...-mounting-rear
petemohr (04-15-2017)
Thanks for the response but I don't understand. Are the shims "U" shaped to fit around and hold the washers in place or around the dog-bone? When you say "loosen the casting and thread the shaft through" this is where I'm having a problem. Has anyone ever posted any pictures of the process?
Greg
#7 and #8 in the illustration below?
Good reminder!
Mine were safety-wired, as I recall (Jeeez, it's only been a few months....what's happening to my memory?) so I re-safety-wired them.
(In fact, I've used safety wire rather than Loctite throughout the car. I just think the safety wire is a neato novelty, I guess. This silliness has added many hours to the already-too-much expenditure of time, not that I particularly care, mind you. I've enjoyed the effort and am gradually becoming more skillful. I've surely wasted 300 feet of wire getting respectable results that I'm not ashamed of, but it's been fun. There's no sensible, logical, practical reason to do this when Loctite is a perfectly good substitute)
Greg in France (04-22-2017)
Doug (04-22-2017)
I didn't remove the mounts from the cage so they should be in the correct position. Would you still recommend removing the front ones to put them on the the body?
Greg
petemohr (04-22-2017)
Greg in France (04-23-2017)
