Instrument Cluster Trim R&R ???
Hi Lgreen
This could be your lucky day, as I also have a 1990 V12 and had to take the Speedo Binnacle out of my Car last year, with a little help from the GF! or maybe that could be the other way round
Anyway taking out the Binnacle is a 10 minute job, although you do need to be careful and use a round nose dinner knife to help to slide those plastic pieces out
And then when it comes to putting them back, put the bottom edge in first which goes between the 'Furry Trim' and the little plastic strip on top (obviously keeping it very tight to the Left or Right of the Binnacle)
Depending on which side of it you are doing
Then as soon as you've got the bottom piece located, you can then fold it back in position and secure it with its screw
Basically just the opposite of the way that you removed it
If you want to read the 'Saga' of how I took the Speedo Binnacle out, when the Speedo Stopped working
You can read all about it here, together with loads of Photo's, which hopefully might help you or someone else
Click: On The Link Below
Removing the 'Speedo Binnacle' from my 1990 XJS V12
Greg in France (03-07-2019)
dwl3858
11-30-2017 08:00 PM
car5car
05-05-2017 09:31 AM
car5car
06-26-2016 05:33 PM
