Intermittent running engine
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks again for all the replies!
I finally replaced the fuel-pump (just to make sure that it could not be the cause) - with no lasting effect. I had enough of it and exchanged the ECU between my cars. I was astonished to find that a 6CU was still installed in the XJS with the intermittent running engine and a 16CU in my backup car. The swap solved the problem right away - it runs again like a dream! i assumed that both my cars had a 16CU - and that was simply not the case. Could have been so easy.......
Best
tfl
Best
tfl
