Intermittent running engine
Old 08-05-2012, 06:09 PM
tfl's Avatar
tfl
tfl is offline
Smile Problem finally solved!
Thanks again for all the replies!
I finally replaced the fuel-pump (just to make sure that it could not be the cause) - with no lasting effect. I had enough of it and exchanged the ECU between my cars. I was astonished to find that a 6CU was still installed in the XJS with the intermittent running engine and a 16CU in my backup car. The swap solved the problem right away - it runs again like a dream! i assumed that both my cars had a 16CU - and that was simply not the case. Could have been so easy.......
Best
tfl
Old 08-06-2012, 05:24 AM
Received 10,474 Likes on 6,917 Posts
SWEET.
Another simple repair to a simple car, got to luv it HAHAHA.
fast40driver
04-19-2024 07:24 AM
toronadomike
08-07-2022 03:41 PM
SD96XJ6L
01-12-2022 04:30 AM
tberg
09-07-2015 07:32 AM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Intermittent running engine
