IR Thermometer
On one of the overheating posts somebody suggested getting a Harbor Freight IR thermometer. I would like to buy one, but, I am concerned about the quality, in this case accuracy, of Harbor Freight's electronic tools. Do any of you have any input on HFs thermometer or suggestions as to other brands, model, cost etc.?
Hi Terry
I have the cheapo Harbor Freight one, which was less than $40, while my wife has a very expensive >$200 one for baking bread (don't ask) I've tried these out together on my hoses and they read within 2 or 3 degrees of each other. In my overheating case I was running 230deg, which is clearly a lot more than the 190~200 I was expecting. I think bocagq45 reported his temps at 260deg, which is extreme. Basically the thermometer doesn't need to be very accurate as there is a lot of difference between "ok" (190 to 200) and "not ok" on the V12 (>230)
I wouldn't buy another IR thermometer... I'm happy with my cheapo one
Hey all,
Thanks for the quick responses, I will pick one up from HF. I wasn't sure if anybody had made a comparison to check for accuracy. I know spot on isn't necessary, but, I'd like to be within the ballpark.
Sarc,
I won't be baking any bread so the HF model should be good enough for warming up a burrito on the manifold.......
Sarc,
hunterpedigo
06-21-2017 08:59 PM
hunterpedigo
10-29-2015 05:31 PM
