IRS Cage Drop Coaching Needed
#121
Nice job, Mac, happy you got her back together. I'm still waiting for some parts to arrive. But grateful for your advice and everyone else's.
Didn't see it in the stickies but found your thread, Greg: https://www.jaguarforums.com/forum/x...cement-148450/
Mkii250 (10-11-2023)
#122
All told I replaced all mounts, brake discs & calibers, shocks & springs, etc. and I before I put all that in the bin, I was wondering if someone might like the old parts? If someone were on a tight budget they might be useful. The mounts were replaced not because any were broken, but just as preventive. The calibers were working fine, but were replaced for the same reason. The shocks and springs were replaced because one shock developed a leak, and I found shocks at Welsh that already had the springs installed so I decided to replace all four. Even the brake pads were in pretty good nick, I'd give them away free to anyone who could pick them up, or free plus shipping.
What do you think? Is it worth putting an ad in Marketplace, or should I not bother?
#123
#125
Doesn't work that way - the bottom seat is fixed, the upper seat has collets similar to those on the valves in a cylinder head see here Rear dampers
Greg in France (10-20-2023)
#126
Greg,
Those collets can get very stuck. Make sure those discs are giving sufficient clearance for you to remove them. See this thread:
Getting the IRS Damper assemblies apart. - www.jec.org.uk
Paul
Paul
Mkii250 (10-21-2023)
#127
pjts, thanks for the link, I am where they were. I sprayed brake cleaner (brakleen) in there but will have to try the cold chisel next. There’s no movement at all. These rotors will work if I can get some movement between the parts. Strangely, the rears I recently removed from the XJS do not have those two extra holes that many have, and so weren’t able to do this job.
jal1234 (10-21-2023)
#128
Mkii250 (10-22-2023)
#129
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/240x320/img_4072_76317fb089bb1dc3a52d1e0ecef1121d144be54d.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/320x241/img_4073_7ccfbc2f0e94acc6ab9e4f7ff91ff8ea45af72b9.jpeg)
This worked. I turned the nuts on the threaded rods so that they pushed the rotors away from each other, with a short headless bolt holding the bottom shock eye under the bottom rotor (second photo). This had the effect of pushing the lower spring seat off the collets, removing the coil spring's pressure from them. A bit of jiggling with a bent screwdriver and the collets fell out. Unwind the nuts and the whole contraption comes apart, with the springs free from the shocks.
As Paul pointed out above, you really want to use rotors whose centre bore is a bit bigger than the lower shock seat inner diameter so that the collets can drop out once free. Rear rotors from the Jag are ideal.
Now back to raking leaves.
#130
#131
As a conclusion to this thread, I wanted to again thank everyone for the great coaching and encouragement to get this done.
Further, I wanted to share an observation of the evolution of my own attitude toward the infamous/famous Jaguar IRS. Before attempting what seemed a herculean feat of removing the unit, my thoughts could be summed up:
'Wait, to simply change brake discs you have to drop the whole cage? That's as stupid as having to drop a Porsche Boxster engine just to change the oil'
'Small differential leak? I have to drop the whole cage? Are you kidding me? Oh, and while I'm at it, I may as well spend a bunch more money completely refurbishing it...'
'What was Jaguar thinking?'
Dread, and nearly a year's worth of excuses to put the whole thing off.
Afterward, I've grown to actually admire the dang thing. It's really an extraordinary piece of innovation and engineering. I find it somewhat fascinating that the same design works in lightweight sports cars like the E Type or AC Cobra replicas as it does in heavyweights like the Mark X or the Daimler DS420, and over a span of 32 years production. I now realize that the ability to drop the entire unit is a feature and not a bug, and it's not as complex or scary as I always imagined it.
The following 3 users liked this post by Mac Allan:
#132
The following 2 users liked this post by Jagboi64:
Greg in France (11-20-2023),
Mkii250 (11-20-2023)
LifesAJaaaaaaaag
07-07-2022 09:49 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
