IRS outer hub bearing trouble too loose
Received 10,871 Likes
Assuming 1996 XJS?
Clearance is determined by various thickness spacers, item #5 in this picture
Hub and Carrier-Rear-4.0/6.0 Litre - Parts For XJS from (V)179737 to (V)226645 | Jaguar Heritage Parts UK
The nut simply prevents the works from falling off the car !![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Often replacement bearings are so close to original in size that changing spacer thickness isn't needed...but variances do occur. Plus, how far onto the shaft you've pressed the bearing enters into the mix as well.
Do you have the shop manual? There should be a section described the measurement procedure to get the right clearance. It's a bit of a PITA.
hawaiianjag
02-22-2016 05:49 PM
Wayne'sJaguar
02-22-2016 03:11 PM
