ISO: XJS Quad headlamps and brackets for swap
As said above, the Kit is complete plug and play. But as you are in Fort Liquordale, try calling Pauls Jaguar. They might be able to help.
Or here https://www.ebay.com/sch/i.html?_fro...light&_sacat=0
If your car is a 1990 USA model it originally had quad headlights and your park/side light is the double filament bulb in the front indicator fitted to the front bumper. Unlike the facelift model which has a small 5w bulb in the euroheadlight. To check just select the first position side/park on the headlight switch. On doing the euro to quad changeout the outer H4 must have whats called "pilot" light. Hope this helps you or anyone doing the swop.
