Is The Italian Tune-Up A Myth? Does It Actually Do Any Good?
Not only "blowing out the carbon' but getting the motor and other systems up to proper operating temperature. keeping it hot enough to burn off carbon deposits on the plugs, piston, and gunk on the valve stems. Runs enough fuel through the system to allow the cleaning compounds to work as designed. Also gets the oil hot enough for moisture to evaporate properly. Even heating up the brakes through use will help keep moisture out of the brake system, especially drum brakes.That is why smaller engines that have to work harder to provide adequate performance often last longer than large motors in cars operated on short trips in town. Think little old lady driving to church once a week. That's why lots of cars with high mileage from commuting still run well. The best thing you can do for your car is drive it.
The following 2 users liked this post by Rivguy:
89 Jacobra (08-13-2018),
orangeblossom (08-13-2018)
It's not ground speed that matters, it's more about putting load on the engine. So for example, if you are merging onto the motorway, use full throttle. Or find steep hills and accelerate up them. Keep "drive it like you stole it" in the back of your mind! Doesn't mean be a hooligan and be hard on the car, just give it some work to do instead of drifting along at small throttle openings.
The other question is, how long does it need to be kept at high revs? Even on the more rural hills, I can seldom manage more than a dozen or so seconds at full boost before I start to run out of road. I've seen some people say it needs to be sustained for at least a few minutes, while others say a quick burst is fine.
Agreed.
Get into it Alex, but watch out in the UK. If you wind it up too far for too long, you might run out of country and end up in the drink, HA.
All mine were driven hard, NOT stupid, but hard.
Long distances are the best, as in hour after hour at 3000rpm or more, really cleans the innards.
100% agree also, with the importance to get it UP to temp before any "clean out" is attempted.
Doug (08-13-2018),
#28
It is reality as I get older, oops, and the Gendarmes get smarter. So I sit at that rpm, and when needed, its gets the red line blast, usually passing a road train or 2.
After a while in the city/burbs, it takes a 100km or so to "feel" settled, so then it just gets better.
Same goes for the current S Type V6's.
#30
Agreed.
Still 'Buzzing' about finding those elusive Fuel Pipe Clips!
But when I'm on those Country Roads, I've somehow taken to using 2nd gear, where the rpm is at around 3000 and overall after that She seems to run much better, although of course She drinks a lot more 5 Star
Where I can almost hear her say, 'don't mind if I do but you better make mine a double'
The only downside being, that I'm getting paranoid about one of those Fan Blades flying off
Do you happen to know if there was ever an option to fit an XJS with a steel fan?
#31
#32
Received 10,920 Likes
#33
Anyhow there's no guarantee against breakage with the steel fans. Check this out:
Welcome to Jag-lovers - Members Photo Viewing Page
#34
The following 2 users liked this post by Doug:
Grant Francis (08-13-2018),
#35
The following 2 users liked this post by Daim:
Doug (08-13-2018),
#36
Jaguar used steel fans until 1981-82 or so. On the XJS I think the change to plastic was shortly before the introduction of the HE engine.
Maybe plastic would leave a smaller dent?
#37
Maybe the early pre HEs? But OEM cream-coloured fans, as per the HE OEM ones from a construction and solidity angle, are available still, but in a slightly larger diameter as used in some saloons and the Daimler limo. Black Country Jaguar have them. I fitted one to a mate's car, which entails removing and discarding the shroud. It needed a 20mm spacer and longer studs being made, but cools the engine incredibly effectively. The normal clutch unit fits fine. Of course, a resourceful guy like you OB could cut down the blades and keep the shroud!
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/720x480/img_3574_99b784b80155c5bd4fa0301c311e0ccef336a11f.jpg)
Facelift Fan cut down to fit inside Pre-Facelift Fan Shroud
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/720x400/fan_with_spacer_d2649c809774377a5033eb32ebe0575b9f93840c.jpg)
Fan with Spacer fitted
The following 2 users liked this post by orangeblossom:
Fla Steve (08-13-2018),
Greg in France (08-13-2018)
#38
Received 2,399 Likes
#39
#40
The following 2 users liked this post by sidescrollin:
