It's ALIVE again!
Received 10,871 Likes
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
AHA, looks fairly "normal" for age to me, and the number of people who try and get a V12 running sweet with that rubbish in there. Plain "old age" and a good job done.
You will do it all again in 20 years time.
I trust you had a beer or 2 or 3 at the end, if NOT, do so, you have definately earned it.
Nah, I gave up drinking years ago for health reasons (my wife threatened to kill me).
I still have work to do. A coolant leak which may be from a bad radiator cap not venting (hoses become rock hard during warm up) and I'd like to find a lower temp switch for the electric fan.
After that, it's on to the new paint job and replacing the convertible top!
Well done James - its a good feeling when you you accomplish the impossible like this. Why don't you have a look at some fire sleeve and run the loom through it no more heat issue.
I am glad you mentioned this - I was thinking about the doing the same thing the BMW harnesses are quite cheap and use good quality high temp wiring. And the connectors are the same.
I started thinking about the mods I've made and decided to make a list.
So far I've:
*Swapped engine from the original 83 to an 85. The 83 had blown head gaskets and unknown damage from heat, so I picked up a low mileage V12 from an 85 and just switched the intakes and externals.
*Removed A/C compressor, lines and cooler. I live in northern New England and it's a convertible. I'll only have it out on days when I can put the top down, so the A/C is kinda pointless.
*Removed air pump, idler pulley, airtubes, tapped and plugged air injection holes in intakes with allen screws.
*Removed cruise control bellows. (I prefer my foot on the pedal!)
*Removed Lucas alternator and replaced with higher AMP GM alt.
*Gutted the insides of the downpipes and hollowed out cat-converters.
*Removed factory mechanical fan and replaced with electric.
*Replaced fuel injection harness and most all of under-bonnet wiring.
*Upgraded ECU
*Replaced 15" wire wheels with Jaguar 16" mag rims and 235/60/16 tires.
I'd guess I've probably easily removed over 200 lbs of "stuff" with the above mentioned mods.
Next on the list is to remove factory fuel regulators and replace with single adjustable regulator with built in gauge.
Replace factory airboxes with cold air intake and low restriction air filters.
I've got a few other things on my list I plan to do as well.
So far I've:
*Upgraded ECU
Obviously a question from someone who does not really understand these things!
Greg
So far I've:
*Upgraded ECU
So far I've:
*Upgraded ECU
I think that the injectors fire in 4 groups of three, so are the BMW versions wired the same?. If so, that would be 2 wires for each group = 8 in total?
If this is correct, then you just carefully ensure the new harness wires go into the same places as the old ones did on the power resistor?
Greg
Let's find out!
Greg
Greg
