Its summer and she is spewing coolant!
I recently rebuilt the cooling system on my 85 v12 so can sympathise. I would be inclined to lean towards a crack in the bottom hose or a leaky cross bar. Water pump is quite unlikely without any obvious noise.
If you do remove the crossbar remember exactly how you took it out and exactly which way the hose clips were facing (the same goes for all the hoses). It is a very very tight fit and quite fiddly to do and get all three hoses back on. Soak them in hot water and don't spare the lube!
If you find a cracked hose, you might want to invest the time to do them all - normally the heater core hoses by the firewall fail first (from my experience) in a spectacular fountain. The bottom hose is a pig, it will be oily and you will get cut - allow at least an hour!
X308XJR
05-20-2019 06:50 PM
