Jag frustration
They have "quick connect" fittings.
This is a snap of the "Set" I have for doing that task.
Readily available at any Auto Parst Stor, and about $10.
You will need to get under the car, and then simply push the selected plastic thingy up into the tank, AND, at the same time push UP on the pipe (this aids the release of the clips inside the fitting), then withdraw the hole unit in one smooth movement.
You will find many posts on this nonsense in the X300 Section, coz that car has them all over the place.
The following 3 users liked this post by Grant Francis:
Jag Frustration
Thanks for the info. I do have another question, with the lines disconnected will the tank slide forward without any issues. Looking up at the fuel lines it looks like a small compartment that the lines come down from the tank, will moving the tank make it difficult to reset that same position.
Grant Francis (04-19-2017)
