Jaguar Factory Phone?
Did your XJS come with an optional Jaguar Factory Phone? Mind did but through the years it is no longer there. (I do have the factory manual for it that came with the car though.) Just four holes in the passenger side of the console where it used to be. I installed a cup holder to cover up the holes. Also cut off the microphone that was at the base of the A pillar. The big problem is the antenna for it that I took off and used a painted plug to cover the hole in the rear fender. Not much else I can do about that other than spending a lot of money to weld it up and repaint the fender. I was curious to see what the phone looked like and if anyone still used one. Anyone have one?
Mine is the same. The mount has been removed and the screws are paint in later colour. The rear antenna has been replaced with a bunt in the hole (will be welded up when I get around to the rear). I'd live to still have it, even though not being usable as the C Network has been switched off...
