Jaguar Lattice Wheels
Does anyone know how the Lattice wheels are finished??? Are they bare aluminum? Or are they simply cleared? Or are they painted?
Daim has a set of the Lattice wheels that are polished on the outer lip only, and I would like to duplicate the process. I'd just like to have an Idea of what I'm up against. If they are painted, I've come up against some Factory wheel paint, that is pretty damn tough, and you end up harming the aluminum, trying to remove it. If anyone has some experience with refinishing/ polishing these wheels, I would sure appreciate any help . Thanks 89 Jacobra
Two methods I have used is either a bath of brake fluid for about 24 hours, that followed by pressure washing takes off oil based paint. It won't touch anything that is latex based. The other option is baking soda blasting. It's very gentle and can take off paint one layer at a time. Might be tough to blast in the lattice though.
Get the paint removed, find a rim repair compamy, let them polish the edge and then get them powder coated. That is how mine will be redone.
It always depends on how you do it. Most i portamt thing: don't use sand to sandblast them Aluminium should be bead blasted (glass pearls) to not only remove the crud but also improve the surface. Even really bad corrosion, deep in the aterial is removed easily. I've had rims blasted a few times and then powder coated... Not once has it been a problem
